pabbly connect issue
Status: Open · Asked by BHUPENDRA RAWAT on · 0 views
BHUPENDER — Question ·
Hi Team,
I'm using google sheet to whatsapp integration using Pabbly Connect, but there is some issue to updation is google sheet.
Error lookout data not found pls help to resolve the issue
Soumya Tripathi — Reply ·
Hello @BHUPENDER
Kindly let us know your workflow ID and the account by which you are using Pabbly Connect so that we can assist you accordingly.
Please be aware that to assist you effectively, we may need to access your Pabbly Connect account. If you're comfortable with this, please grant us permission by stating in your next email: "You have my permission to log into my Pabbly Connect account, and edit workflow {If required}. Here is the registered email address associated with it."
Soumya Tripathi
Rate your support
[QUOTE]
[/QUOTE]
BHUPENDER — Reply ·
Hello @BHUPENDER
Please note down my id [email hidden] and the error is attached.
Hello @BHUPENDER
Could you please let us know if you have changed the response of the trigger application "Webhook by Pabbly: Catch Webhook (Preferred)" The previously mapped data is no longer visible, and it is showing an error.
We request you to re-map the action steps in your workflow accordingly.
Soumya Tripathi
Rate your support
[QUOTE]
[/QUOTE]
