Pabbly Connect not Capture Webhook Response
Status: Closed · Asked by invet21 on · 0 views
invet21 — Question ·
Hello everyone! I want to send messages from Google Sheet to Whatsapp but Pabbly Connect does not receive the data that I upload in the form. I'm stuck in the initial setup.
Any help appreciated. Thanks.
invet21 — Reply ·
Yes! I sent test data from initial setup. I have already followed the instructions in that same video.
invet21 — Reply ·
Performing a shipping test after a while I still do not return any results.
Fagun Shah — Reply ·
Try sending test data from incognito mode.
Fagun Shah
- Automation Freelancer
invet21 — Reply ·
Thank you! Now it works. But the messages are being sent duplicates.
I'm texting plus a photo. But in the tests the message arrives first twice and then twice the photo.
Hey @invet21
We looked into the concern and checked all the recent history logs but we couldn't find any duplicate data which was sent twice through your automation.
For this, you can pick the "Send Message" action step of ChatAPI after the "Send File" action step, so that you will get the Image first and then the Message.
