Pabbly Connect not loading Triggers/Actions
Status: Closed · Asked by MouradAz on · 0 views
Greetings, my Pabbly connect doesn't load any triggers/actions and when I search for an App 'aka: webhooks' nothing shows, it also doesn't let me create new workflows as the button isn't there at all.
Thanks in advance.
Hi @MouradAz,
If you are using Windows, please press CTRL + Shift + R to hard refresh your browser and see if that fixes your issue. If you are using a Mac, press Command + Shift + R to hard refresh the browser.
Also, try using a different browser or device to see if that resolves your issue.
