Pabbly Connect Not working for tumblr
Status: Closed · Asked by vks on · 0 views
Hey
I connected my wordpress site with Tumblr using Pabbly but it's not working? When i try via sample response its working fine but when i do posting it didn't work
Hi @vks,
Based on the workflow you have shared, it seems like you haven't set up your WordPress trigger step properly. Please disable this workflow and set up a new workflow from scratch (without cloning).
Follow the exact steps given in the video attached below to set up your workflow.
hey check now it's still not working https://connect.pabbly.com/workflow/sendwebhookdata/IjU3NjUwNTZjMDYzMTA0MzY1MjY4NTUzNzUxM2Ei_pc
Based on your Task History, I can see that the post was captured from WordPress and posted to Tumblr. Please make a dummy post on WordPress and see if the same post is published on the Tumblr page or not.
If the issue persists, please record a video showing the entire process of you making a post on WordPress and it not being published on Tumblr.
