Pabbly Connect Not Working - Workflow end task not executed
Status: Closed · Asked by Shariq Saeed on · 0 views
Shariq Saeed — Question ·
I am unable to send msg through pabbly connect all the procedure completed end portion just not working also please help me sending messages in bulk i do not have any idea how it works
Hi @Shariq Saeed,
The issue you are encountering occurs when a user hasn't setup their WhatsApp Cloud API account properly or when the temporary token has expired.
Please follow the exact steps given in the video to setup your WhatsApp Cloud API.
youtube.com/watch?v=qAzhxOpv5JY
Once you have set up your WhatsApp Cloud API account, establish a new connection with your WhatsApp Cloud API account and make sure you enter the Permanent Token.
Watch this video to understand how you can generate Permanent Token in WhatsApp Cloud API.
youtube.com/watch?v=y2beqnlim6g
Shariq Saeed — Reply ·
Thank you for reply , now i am facing this when adding whatsapp number , only thing left is mapping number while sending at the ending
I am facing this error
Even this error seems to be related to your WhatsApp Cloud API account setup. For this, you would have to get in touch with Meta's support team as they are better equipped to handle this concern of yours.
