Pabbly Connect not working
Status: Open · Asked by N Prep on · 0 views
Gourav Khurana — Question ·
I am using pabbly connect to setup automatic replies of Youtube through Chatgpt. When I set it up, it was working for a test response, but as soon as I save and close the workflow after enabling it, it doesn't work in background. What should i do?
Hello @Gourav Khurana,
Upon reviewing the task history of your workflow named "yt," we found that it has been functioning correctly. Please refer to the attached image for more details.
Additionally, the 100-task limit under your free account has been exhausted, preventing the workflow from running further.
To continue using the workflow without interruption, you may consider upgrading to one of our paid plans based on your requirements. For more details, please refer to the following link: https://www.pabbly.com/connect/#pricing.
Let us know if you need further assistance.
