Pabbly Connect Telegram error code 400 after testing
Status: Open · Asked by Convo8 on · 0 views
Convo8 — Question ·
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
Hi, I have issue getting my FB lead form input to be reflected on telegram. I have this error code 400 (attachment below). I have tested without the input and it does go through. Need help to resolve the input part.
This is the description error
Bad Request: can't parse entities: Unsupported start tag "test" at byte offset 157
Hi @Convo8,
Thank you for reaching out and sharing the details.
Upon reviewing the error message, it appears that the issue is likely related to the Telegram action configuration.
However, at the moment, we are unable to fully check the workflow configuration from our end since you have not granted consent.
If you could please provide us with the consent to access your Pabbly Connect account, we will be able to identify the exact cause and assist you with a precise solution.
Looking forward to your confirmation.
Convo8 — Reply ·
Hi Preeti Paryani,
sorry for the late reply. for the issue, I am able to rectify my own by creating another new lead from lead centre instead of the dummy lead. Thank you
Thank you for the update. We’re glad you were able to find a solution.
Arshil Ahmad
?Rate your support
