Pabbly Connect will not get past initial set up
r1se yoga
When I click on the Sub it or Send Test Button nothing happens. no webhook is caught in Pabbly.
I am using Incognito mode. See image as to where it gets stuck.
This is vital to me.
I love Pabbly but do prefer how Zapier worked with Google Sheets without the need for an extension.
Please assist.
Many thanks
Chris
Hey @r1se yoga
Seems like you haven't captured the webhook response correctly. Please refer to the following video tutorial for your better understanding.
(Watch the first part of the video)
r1se yoga
Sorry, this video does not seem to be what I needed. It is a 17 minute video about WhatsApp etc.
I am not sure how I could be setting up the webhook differently. It is simple.
Issue is when I test it in a Google Sheet using Pabbly Connect i never get a webhook sent. Please help this is critical.
Please assist.
Many thanks
Chris
As we can see from your previously mentioned screenshot you have captured the webhook response correctly.
If you only see the first part of the video you will get the correct way to capture it. Also, try capturing the Google Sheets webhook response in the incognito mode of your browser if you have multiple Google Accounts it might interfere with your connection.
