Pabbly Delay: Delay after Queue
Status: Open · Asked by Ilan Freeman on · 0 views
IlanFreeman — Question ·
Task History ID: IjU3NjUwNTY4MDYzNjA0MzE1MjY5NTUzMDUxMzU1MTY3NTQzNDBmMzQi_pc
I am trying to understand the Delay after Queue.
I am running a workflow that starts with a webhook that updates contact information based on a transaction. However, the payment software takes every line item as a separate transaction in the webhook, which causes overwriting because they happen simultaneously.
I am trying to set up a queue delay so that if four webhook events happen simultaneously, they will all be delayed by 1 minute. However, when I look at the task history, it seems like each webhook is just being delayed by one minute. So they all come in at 10:40 and then execute again at 10:41.
Am i missing something?
I added a few screenshots as well
Hello @IlanFreeman,
At the moment, there are some ongoing issues with the “Delay After Queue” module in Pabbly Connect. Our team is actively investigating the matter.
As soon as the issue is resolved, we will inform you. Once it's functioning properly, you can monitor how the module behaves, and I’ll also walk you through how it’s expected to work.
We appreciate your patience and understanding.
IlanFreeman — Reply ·
Thank you. I will keep an eye out for your follow up.
