Pabbly delay function
Status: Closed · Asked by 99 Interactive on · 0 views
youtube.com/watch?v=HJ967vgDLVw
went through the above video.
How long can a delay work according to this, depending upon custom input, can i have delay of 1-52 week more often in a single workflow. ?
@Supreme
@Supreme
Yes, you can set any number of weeks for setting up the delay. There won't be any problem in that.
@Pabbly
what happens after a period of time in such work flow 1 or some internal app changes to `The Action is deprecated` will that makes us do know which triggers are yet to be executed this point onwards.
and please correct me for the following statement if any error
"i can have multiple delays in a single workflow that start until a specific date every time as mention in delay module, without any error."
Hey @99 Interactive
The deprecated action event will be only be active till 12 months, though it will function the same. You can check the task history Id for your scheduled action step for the live execution.
Further, you can use multiple delay action step in your workflow easily. As of now Pabbly support is not available on calls.
@Supreme Thank you
