Pabbly - Flowlu Integration problem
Status: Closed · Asked by rupesh on · 0 views
It seems that Flowlu/Pabby integration doesn't support the custom field of opportunities. Can you help with this? I raise this with flowlu team as well and they suggest to raise with you and request you to respond to them for this and full integration.
Hey @rupesh
As per Flowlu's API documentation, Flowlu doesn't support custom fields of "Opportunity". Here's the documentation of Flowlu API for the same -
https://www.flowlu.com/api/#tag/Opportunities/paths/~1crm~1lead~1create/post
In the future, if they start supporting custom fields in their API, we should be good to go for updating the integration at our end for supporting custom fields.
@Supreme Flowlu does support custom fields for Opportunity (or leads), you have to filter on fieldset = 3 (filter[fieldset_id]=3)
