Pabbly - Flowlu Integration problem
Status: Closed · Asked by rupesh on · 0 views
rupesh — Question ·
It seems that Flowlu/Pabby integration doesn't support the custom field of opportunities. Can you help with this? I raise this with flowlu team as well and they suggest to raise with you and request you to respond to them for this and full integration.
Hey @rupesh
As per Flowlu's API documentation, Flowlu doesn't support custom fields of "Opportunity". Here's the documentation of Flowlu API for the same -
https://www.flowlu.com/api/#tag/Opportunities/paths/~1crm~1lead~1create/post
In the future, if they start supporting custom fields in their API, we should be good to go for updating the integration at our end for supporting custom fields.
Hermes — Reply ·
@Supreme Flowlu does support custom fields for Opportunity (or leads), you have to filter on fieldset = 3 (filter[fieldset_id]=3)
Best regards,
Hermes
Connect with me on LinkedIn
