Pabbly Forms Uploaded Images to Pabbly Connect
pulboron
Hi there, I'm trying to do this integration:
Pabbly Form (File Upload) -> DynaPictures -> WooCommerce
Basically the flow should be:
1. Image uploaded in Pabbly Form
2. Image is enriched in DynaPictures
3. Product Created in Woocommerce using enriched image
However, Pabbly Forms api response does not have the actual image URL. Instead it has a link that initiates a download.
The Dynapictures API does not seem to be compatible (it expects a URL with the file extension -i.e. *.PNG). The images turn out blank.
Has anyone been able to do this kind of process successfully?
Thanks in Advance!
Supreme
Hey @pulboron
As of now, Pabbly doesn't support the attachment field to upload a soft file from the desktop. So your use case cannot be possible.
