Pabbly Membership Problem
Status: Open · Asked by Bananajuice2002 on · 0 views
I purchased the first tier of Pabbly membership on April 20th, which gives me access to 12k tasks. Today, when I tried to create a new workflow with Open AI, an error appeared. Additionally, the old workflow that I had for about a month started having the same error message, which reads: "You exceeded your current quota, please check your plan and billing details," with an error type of "insufficient_quota."
I'm confused because I have an active subscription, so how is it possible that I exceeded my quota?
Hey @Bananajuice2002,
Thank you for a quick response. Done. I added you.
The error message you're seeing is from OpenAI. I recommend contacting their support team to get a better understanding of the error.
https://help.openai.com/en/articles/6891831-error-code-429-you-exceeded-your-current-quota-please-check-your-plan-and-billing-details
