Crlnt
Hello. This question might sound silly but can I reuse the same existing connection over and over again? For example, I'm creating a new workflow for our CRM. I already used it in another previous workflow so there is an existing connection #1. Should I create another connection for this new workflow or can I reuse the same existing connection? What's the difference?
Thank you.
Thank you.
