Pabbly new connection and existing connection
Status: Closed · Asked by Carilyn Tolentino on · 0 views
Hello. This question might sound silly but can I reuse the same existing connection over and over again? For example, I'm creating a new workflow for our CRM. I already used it in another previous workflow so there is an existing connection #1. Should I create another connection for this new workflow or can I reuse the same existing connection? What's the difference?
Thank you.
Hey @Caryl
In Pabbly Workflow, you can absolutely reuse the same existing connection over and over again. You do not need to create a new connection every time you want to integrate with the same application or service unless you are having several accounts with different names.
This is helpful. Thank you!
