Pabbly not inserting custom fields properly
Status: Closed · Asked by Micahel on · 0 views
Micahel — Question ·
Hi, sometimes in my automation to add a contact to a list on HubSpot as opposed to someone's email address, Pabby inserts the below string:
1. Data Attributes Email Address : {{{_map_val_{{{[email hidden]}}}_map_val_}}}
Is it something fixable from my end or a software error? During a test, it works properly.
Hey @Micahel
Can you please share the workflow URL in which you have experienced the same error so that we can look into it?
Hey @Micahel
Can you please try clearing your browser's cache memory once and then try the automation?
Micahel — Reply ·
It works now, but the problem is it happens from time to time on the workflow that works properly most of the time
Thanks, for the update, you can try updating the Pabbly connect workflow in the incognito mode of your browser.
