Pabbly Not Retrieving Fields from Flowlu
Status: Closed · Asked by MBO on · 0 views
PabblyMember4 — Reply ·
Hey @MBO
We have checked the endpoint and we have found the support for the custom field was already enabled. While creating your API key in Flowlu you have to click on Custom Field checkbox to make it enable. Kindly check the below screenshot:-
You can check thebelow video from 9:07 mintutes for getting custom field information in Flowlu.
youtube.com/watch?v=rJ9fE3EzBBo
