Pabbly not sowing fields on leadconnector
Status: Closed · Asked by Pritesh Patel on · 0 views
why does create opportunity on leadconnector not give the all the custom fields to input data into?
I added a question on my facebook lead form and created the custom field on leadconnector for it but I had to use "create or update contact" to see the field on pabbly.
I tried to update the api.
Hey @p14
As we can see from LeadConnector/High Levels' API documentation and they haven't mentioned any support for Custom Fields in creating the opportunity.
So, are currently working on it and will notify you with an update soon.
