SupportHubstrat
- Your Workflow URL
- https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZmMDYzZTA0MzE1MjZhNTUzMzUxMzMi_pc
- Your Task History ID
- IjU3NjUwNTY0MDYzMDA0MzQ1MjY5NTUzMTUxMzY1MTZiNTQzNTBmMzMi_pc
- Consent to Access & Modify
- I authorize Pabbly Support to log in to my account and make changes to the specified workflow for troubleshooting.
Hello, we received an error in one step of the automation you reported.
Specifically, the error reported is:
Success
false
Error
querystring/term must NOT have fewer than 1 character
Error Info
Please check developers.pipedrive.com
Data
null
Additional Data
null
Can you check the reason for the error?
thanks
Success
false
Error
Error Info
Data
null
Additional Data
null
thanks
