[Pabbly + Pipedrive] Errorquerystring/term must NOT have fewer than 1 characters
Status: Closed · Asked by SupportHubstrat on · 0 views
SupportHubstrat — Question ·
Task History ID: IjU3NjUwNTY0MDYzMDA0MzQ1MjY5NTUzMTUxMzY1MTZiNTQzNTBmMzMi_pc
Hello, we received an error in one step of the automation you reported.
Specifically, the error reported is:
Success
false
Error
Error Info
Please check developers.pipedrive.com
Data
null
Additional Data
null
Can you check the reason for the error?
thanks
Hi @SupportHubstrat,
Upon checking the task history, it appears that the error is coming from the Pipedrive: Find Person action.
In this step, the Email field from the Google Sheets trigger is mapped to search for the person. However, in the specific task where the error occurred, the Email field did not contain a valid value, which caused the query parameter to be empty.
Because of this, Pipedrive returned the error: “querystring/term must NOT have fewer than 1 character.”
Please ensure that the Email field always contains a valid email value in Google Sheets to avoid this issue in future executions.
SupportHubstrat — Reply ·
Thanks for the feedback
Hey @SupportHubstrat,
Glad to be of help!
As your concern has been addressed, we’d appreciate it if you could share quick feedback on the support received:
Thank you for your time.
PS: We are closing this thread as the issue is resolved. Please feel free to reach out to us if you face any issues in the future.
