pabbly rss trigger does not fetch post thumbnail
Status: Open · Asked by serwar habib on · 0 views
i want to save my post title, URL and features image in google sheet
I tried pabbly RSS trigger and also tried Wordpress trigger but none was able to feature post features image and add that in google sheet. please tell me how can I achieve this. thank you.
Hi @serwar24554,
you can see it does not fetch the post image.
Hello @serwar24554,
Could you please confirm if the image URL shown in the attached screenshot is the one you want to add to Google Sheets Additionally, let us know:
- Do you want to save all the image URLs (including different sizes) for the same image
- Will there always be just one image in the feed, or could there be multiple images
This information will help us understand the use case accurately.
i dont see any screen shot. i just want post featured image to be fetched and then I could map the featured image as needed.
Hello @serwar24554
We have added a new action in WordPress that allows you to retrieve the featured image. However, you will need to install a plugin in your WordPress account to enable this functionality.
Ensure the JSON Basic Authentication plugin is installed on your WordPress account.
- Refer to the attached image for guidance.
- You can follow this thread for detailed instructions on installing the plugin: https://forum.pabbly.com/threads/wordpress-error-rest_cannot_create_user-sorry-you-are-not-allowed-to-create-new-users-401.813/.
[IMG alt="image (59).png"]https://forum.pabbly.com/attachments/image-59-png.49051/[/IMG]
- If you have the Mini Orange plugin installed, please uninstall it as it may cause conflicts.
- Double-check that dynamic data is mapped correctly in your workflow. If not, the order details may not be retrieved or updated as expected every time.
Once done please let us know.
attached image is not viewable
Hey @serwar24554
Kindly check below the image referred to
Let us know if this works for you.
