Pabbly to Go High Level (LeadConnectorV2) issues
Status: Closed · Asked by BPP_ColeSlaw on · 0 views
BPP_ColeSlaw — Question ·
Hello. I have had automations running great for about 3 weeks now and then all of a sudden about 3 days ago stuff started falling apart and I am not sure why. The errors are all over the place.
Here are a few errors I have recieved, most of them are when an even takes place into Lead Connector
Message
Unexpected token " in JSON at position 0
Error
Bad Request
StatusCode
400
Message 0
customFields must be an array
Error
Unprocessable Entity
StatusCode
422
TraceId
9cec4467-8e40-4ae4-90ff-0a57603e0442
StatusCode
403
Message
The token does not have access to this location.
Here are steps I took
-Reintegrate connection (tried twice) (was successful both times but error still persists)
-Added delay before the event in a few workflows to see if waiting helped (it did not from what I can tell)
-Refreshed fields and ran through workflow build in testing environment
-Waited for failed attempt, capture the failed attempt as test response, ran through and tested, everything worked great when going through the steps one by one.
Not sure what to do becuase these issues are over my head
For context, I have a Shopify store and use GHL as my CRM and grab data from Shopify, and GoHighLevel and filter it trhrough pabbly so if something changes it syncs up. It also is a vital part of my order processing set up so errors mean customer confusiuon.
Thank you in advance!
Hi @BPP_ColeSlaw,
BPP_ColeSlaw — Reply ·
Thank you for sharing the Workflows. Please allow us some time to look into this concern. We will get back to you with an update soon.
