Pabbly to Motion
Status: Closed · Asked by Nexify on · 0 views
Hello, I have an automation that tries to create a task in Motion.
But the motion step comes back with an error, see screenshot.
It mentions the due date... is it an invalid ' in the date?
I cannot see a quote in the due date. I contacted motion and they ask for the full JSON request, but I cannot see that, can I?
Maybe it is easy to fix. It is workflow: https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZlMDYzNjA0MzE1MjZlNTUzMTUxMzUi_pc
Hey @GroeiGarage
Please refrain from populating the "Sub Tasks Completed" field at this time, and proceed with the task. This should enable the workflow to function properly.
@Nexify Would like to know if Motion integration has been working in Pabbly? I haven't been having much luck. I am trying to do some linking between Motion and Asana.
Hi @indyarkyguy
Yes it has. It is quite finicky though in configuring. As in it requires quite specific settings.
What are you running into?
Hi @indyarkyguy
Well...even if you could point me to a video to watch, or something. I am trying to link Asana (client is making me use this) and Motion. If a project is created in Asana and assigned to me, I wanted to link it so it created a project in Motion. However, when I put the "Trigger Event is New Project" in Asana...when I go to Motion to "Create a Project" it is asking me for the Project Name. Well, I don't have a project name because it hasn't been created yet. I think I am missing something here.
Can you please share the workflow URL once in which you are trying the same and the steps you are getting stuck?
