Pabbly triggered error: Integration between Zoom and ActiveCampaign
Status: Closed · Asked by CNX Marketing on · 0 views
CNX Marketing — Question ·
Halo everyone!
currently, I am using Pabbly to connect between ActiveCampaign (AC) and Zoom, the flow is like this:
First step: When a contact is added to AC's list (let's call this list as list A)
Second step: Then it will auto send the user details to ZOOM for meeting registration.
Conclusion: The automation rule will trigger when there is a contact is added to list A, then it will auto-register in ZOOM meeting
But now the problem that I facing is when a contact is added in AC, Pabbly will automatically help me register in ZOOM, even the contact is not inside the list A
Is anyone facing this problem? Can someone advise me?
Thank you.
Hey @CNX Marketing
The Active Campaigns' trigger event doesn't validate the contact on the basis of a particular List. But you can use a filter action step to receive contacts only from the particular List.
Kindly try this at your end and let us know if that works for you.
CNX Marketing — Reply ·
Hi @Supreme
where can i find this filter feature ya?
