Pabbly Webhook not working
Status: Closed · Asked by olimp6990 on · 0 views
Hello, has anyone faced an issue while connecting Pabbly Connect Webhooks with google forms ?
I did EXACTLY step by step as this video shows
youtube.com/watch?v=0Hh5yLcyrQc
I have done this several times
(Last question in google forms is set to required)
The problem is that it keeps waiting for the response and nothing is happening ...
Anyone can help me fix this?
Hey @olimp6990
Kindly try capturing the webhook response in the Incognito Mode of your browser and then try again.
Seems like you have multiple Google accounts opened in your browser perhaps that could be possessing the error while doing the initial setup.
You can refer to the following video tutorial on how you can use the Google Sheets trigger event.
(Watch the first part of the video)
