Pabbly Workflow for Social Media posts not working.
Status: Closed · Asked by Skye Khilji on · 0 views
Hi all!
Recently created Pabbly Workflow for social media - Twitter and LinkedIn, works when I test it but does not work as it should automatically.
1️⃣ For Twitter - It should send a message to a Slack channel whenever a new post is created.
2️⃣ For LinkedIn - The trigger is whenever a status is updated on Notion then if there is a Link/Content on a specific cell, it would send a message in Slack.
None of these are working. Please let us know what we're overseeing.
Thanks!
LinkedIn workflow:
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZjMDYzNDA0M2Q1MjY5NTUzMjUxMzYi_pc
Hey @SkyeFWP
Could you kindly attempt to capture the webhook response once more before giving it another try?
Hey @SkyeFWPCould you kindly attempt to capture the webhook response once more before giving it another try?
didn't work ☹ thank you!
Kindly check the RSS link which you have provided in the trigger event, seems like it is not the correct one.
Additionally, we have decreased the polling time from 8 hours to 10 minutes. Therefore, could you please attempt to run the workflow by updating the Notion database in the respective one?
