Pabbly X WATI integration and time delay issue
Status: Closed · Asked by heypkay on · 0 views
heypkay — Question ·
Hi, I've setup a workflow which triggers a follow up message after 4 hours of someone signing up on my landing page with their details. Now, everything is set-up and looks fine inside pabbly. But the issue that I'm facing is the WATI message is being sent at the time when the person is signing up and not after 4 hours. I've set-up a time delay and changed the time to add 4 hours in the time when the event is created.
Can someone help me fix this? I first tought it was a WATI issue but now I think it has to do something with the pabbly trigger not working/delaying the time by 4 hours.
Let me know if you need any more information from me to guide me further.
thanks.
Hey @heypkay
Since the Delay action step is not set up after the trigger event before the WATI action step it will send the message instantly.
heypkay — Reply ·
Hi, there are in total 3 messages that I want to send - one instantly, one after 4 hours and one after 20 hours. And at the same time, I want to filter them so that they aren't sent out between 11 pm to 8 am.
Check the screenshot, after the initialy trigger event, I've added change date/time (step 2) to add 4 hours in the time and then created a flow that filters non-working hours and working hours to sent out the message.
Let me know if this helps you to find me a solution?
thanks.
