Pause script, approve input and continue....
Status: Closed · Asked by pierrevanlier on · 0 views
Using an automation that starts with a google form and then launches the other modules from a google sheet. We need some kind of approval mechanism, where the rest of the automation only launches once approved.
I am thinking about adding an extra column in the google sheet that once ticked or filled will launch the remaining modules in the automation. I would then specify this extra column as the initiating column in the pabbly connect webhook settings. Unless there is a better way to do this.
Is this the best way to do this?
Hey @pierrevanlier
Your use case and working seem fine to us, you can give it a try at your end. Further, do let us know the name of your workflow to review it and if you get stuck at any step then do let us know.
