Payment gateway (Pay tabs) Integration with (Mind Body)
Status: Open · Asked by Vikram Doss on · 0 views
Can you please advise the compatibility for an integration, we have a requirement to integrate payment gateway and an application software for our business.
- Pay tabs (Payment Gateway)
- Mind Body (Software)
Mind Body Software team confirmed us that they don’t have a relationship with Pay tabs for API integration from their end and it’s not support. can you please let me know is possible for you to create custom API or other ways to make it possible.
Hi @Vikram Doss,
Currently, we don't have a direct integration with the PayTabs application. If you would like to see this application added to Pabbly Connect, you can submit your request on our dedicated platform: https://pabbly.hellonext.co/
Our integrations team will review your request, and if possible, add the desired application to Pabbly Connect.
In the meantime, if PayTabs supports webhooks, then you can use Webhook by Pabbly to achieve your use case.
youtube.com/watch?v=FRkl5R7-Ls0
We do have an integration with Mindbody, and you can use any of the given action events.
Thank you for the details, but I am not able to understand how to use webhooks to integrated Pay tabs as payment gateway for Mind body.
Please contact PayTabs' support team to inquire about their support for webhooks and confirm whether they are providing webhooks or not.
Incase they provide webhooks, then you will be able to use Paytabs in the trigger step.
Meanwhile do check below video which explains about what are webhooks and how to use them -
