Phone number is not showing in Webhook response
Status: Closed · Asked by Anoop on · 0 views
Anoop — Question ·
Hi
Phone number is not showing in Webhook response please help my website URL is https://rabat.run/
I have phone number field in my registration form
Oleksandr — Reply ·
Although its not exactly the same issue, but I had a similar problem with calendly. What I did was:
Instead of using the "standard" phone number field, I had to create a simple text field for the customer to enter their phone number.
Hey @Anoop
We looked into your worklfow and it seems like you might not have captured the correct webhook response from your form and because of that you were not able to get the phone number accordingly.
Though we have configured your trigger response accoidngly and map the phone number too. Please give have a look and try again.
