Pipe Drive to Go High Level
MTR-IT
So my trigger application is PipeDrive and when a Lead is created I want a new contact to be created in GHL.
The GHL is not showing the populated fields so that I can map it.
Supreme
Hey @MTR-IT
As we can see from your workflow after reconnecting the GHL action step your custom fields are getting populated completely.
Please check that out -
PabblyMember4
Hey @MTR-IT
Could you please try to restart the laptop and use other browsers like Opera, and Firefox and then try to access the workflow? Kindly let us know if it helps.
Supreme
Hey @MTR-IT
As we can see from your task history Id it seems like from Pipedrive you didn't get the email address in the mapped label which you have used.
So, kindly recapture the webhook response and then remap the value in the GHL action step.
