pipedrive endpoint issues
Status: Closed · Asked by viniciussricci on · 0 views
viniciussricci — Question ·
Task History ID: IjU3NjUwNTZhMDYzZTA0M2Q1MjY5NTUzMjUxMzUi_pc
Good afternoon!
It's not new that I'm facing several problems with the Pipedrive APIs, to be more specific in the "Find or create the person" and "create lead" end points, basically there are two cases, the first is when it doesn't send the data to find or create the lead, even though they are registered and the second is when it will create the lead (this is more common) basically the pipedrive says that no organization or person was sent for assignment, even though everything is correctly filled out.
I need you to fix this, I have more than 16 clients who use this integration and I'm already running out of patience, as I have to keep correcting all of this by hand, as your re-execution doesn't work on this occasion and the error continues to occur.
viniciussricci — Reply ·
IjU3NjUwNTY1MDYzZjA0M2M1MjY1NTUzNTUxMzUi_pc
Another with many issues
I understand that some errors occur due to a returned array, but some examples like this:
it is not an array that is returned and the error happens anyway
