Pipedrive - fields spread over separate actions (or not shown) causes unneccesary task usage
Status: Closed · Asked by Support - FINSPRO FINANCE on · 0 views
another thing that bugs me is:
Having not all fields either available or in the same way leads to using of multiple steps (e.g. Update Person / Update Person with custom fields or Create Deal vs Update Deal w. custom fields.
They do not treat all fields equally or do not have them all at one which leads to using double task (step).
Same for the Note for Deal:
I can make the Note, thats working, BUT in zapier i can see the feature to pin this note to the deal, to a person, organization etc.
And these fields i get back also as answer from api (see screenshot below) but i can not select them in advance, so i have no chance to also get the note to customer except creating a new step to create the same note for person, but thats another extra step :/
Can you tell me if i am doing anything wrong or how can i fullfill the needs without wasting steps / tasks?
Thank you in advance.
BR
Christian
The action events are set up according to the API documentation of the application. Could you please make a short screen recording showing some examples of the discrepancies you encountered so our team can better understand them?
Good morning @ArshilAhmad ,
thank you, i understand of course that you rely on the API but the question is more, how the API access and usability is setup then here for pabbly connect.
I explained also some differences in the steps and fields in my post here:
https://forum.pabbly.com/threads/pipedrive-different-behavior-for-same-fields-in-different-actions.26832/#post-130219
This makes it partly neccessary to setup multiple steps which costs unwanted tasks plus much more incosistent and inconvinient.
For the example above, as you can see there is - as example - the feedback from the Pipedrive API that lets me pin this note that i am about to connect to a deal also in one step to the respective contact , organization or even lead.
This is the functionality that i use already in Zapier for example to get this note also into customer itself.
I will check this more out if i miss any point here, but thats what i mean that is not fully accessible even it is there from the api.
If you need anything more, i am happy to help out and / or discuss :)
Have a good day!
Regards
Christian
Hi @Finspro,
Could you please confirm if the following endpoint works for you Our team will review it and consider adding it:
https://developers.pipedrive.com/docs/api/v1/Notes#addNote
Hi @Preeti Paryani ,
these information seem to be the ones i miss in the current setup, looks good :)
BR
Christian
Hi @Finspro,
Thanks for the confirmation. I will escalate your request to our technical team, and once the action is created, we will update you accordingly.
Perfect, thank you in advance @Preeti Paryani
Hello @Finspro,
We’re pleased to inform you that our team has successfully added the "Add a Note" action event in Pipedrive.
Please try using it on your end and let us know if it works as expected. Feel free to reach out if you need any further assistance!
Perfect, thank you very much for this @Preeti Paryani , will check it out and come back if additional questions arise.
Have a good day!
Regards
Christian
