Pipedrive Webhook Endpoint issue with Pabbly
Status: Closed · Asked by Xartup Fellowship on · 0 views
Hi Team
While we are trying to update a deal on pipedrive, there is an endpoint issue with pabbly which is leading pipedrive to throw a 404 error. We tested the webhook with the same input and it is working with 200, but the pabbly webhook is throwing an error.
This is a bit urgent as our operations is dependent on this. Please help us resolve it. Screenshot attached below for the same actions - 404 with pabbly webhook.
Hey @Xartup
Could you please tell while using the workflow, was the workflow is in the switch on condition or not. Since the 404 error only appears when the workflow is in off condition and users try to pass the data in it.
You can check the same on the following thread also. Kindly check that out.
https://forum.pabbly.com/threads/status-codes-and-maximum-payload-size-limit-of-webhooks-by-pabbly.4277/
