Plan for Update Pabbly to have Web ChatBot Flows designer function ?
Mijares72
Hi @Neeraj and @ArshilAhmad , I've been a Pabbly Connect user for a few months and I'm delighted. The fact that they keep adding features and capabilities is the greatest added value, of course, in addition to the fair pricing.
I also use the Landbot tool to create web chatbots (agents), and it's worked well for me because with Webkooks' features, I integrate perfectly with Pabbly. However, Landbot is stagnant; it doesn't generate new features or integrations, and its pricing is high.
I would love for Pabbly to develop the tool to create web chatbots, absorbing Landbot's functionality, so I can then move away from that platform and migrate my nearly 200 bots I have running with them to Pabbly as well.
Are there plans to create this module in Pabbly? I think it could be an evolution of the Pabbly Flow tool, allowing for not only WhatsApp bots but also web and multi-channel bots.
What do you tell me about it @Neeraj ?
Regards
ArshilAhmad
Moderator
Hi @Mijares72,
That’s a great idea! You can submit it on our dedicated platform, where our development team actively reviews suggestions. They will look into your idea and consider it for future updates.
bet365ainfo
This would be a fantastic addition to the Pabbly suite!
Having a visual chatbot flow builder — similar to tools like Landbot or Dialogflow — would not only simplify user interaction setup but also make Pabbly a much stronger competitor in the automation + marketing space.
Especially with the growing trend of conversational UI and no-code tools, a web chatbot designer could unlock more use cases like lead qualification, customer support, and onboarding automation — all within the same ecosystem.
Really looking forward to hearing if this is on the roadmap. Count me in as an early tester if a beta becomes available!
ArshilAhmad
Moderator
You can check out our roadmap here:
If and when we add the tool you’ve requested, we’ll be sure to let you know.
