Plutio "Create Contract" Issue
Status: Closed · Asked by JWB502 on · 0 views
Im testing out some automations/workflows and I am trying to automate creating a contract using a template...is this possible?
No, but I dont understand why you want to.
Within Pabbly we have the possibility to create and update persons. The fields we can fill are limited, thats why I have requested for more fields: https://pabbly.hellonext.co/b/Update-Existing-Application/p/plutio-create-update-person-with-more-fields
Please upvote it and update it with the fileds you need.
@JWB502 what you need to know about creating task (or others) using a template is that Plutio then creates a task like the template. After that you need to edit that task to fill in the fields you want.
