Plutio Not Connecting
Status: Closed · Asked by Camilo A. López B. on · 0 views
I'm getting this error while connecting with Plutio.
Can I get some help, please?
Kindly pass the company Id instead of passing the company name.
e.g. -
Kindly pass the company Id instead of passing the company name.e.g. -
Does it mean I can't create a contact without having a company already created at Plutio?
You can create a contact in Plutio but you need to select the company from the dropdown or need to pass its Id.
Plutio: Create Person
I keep getting an error.
Warning
Invalid Credentials or Business Identifier
I put in all the info from Plutio and it give me that error.
thanks
Hey @i5marketinginc
Can you please share the name of the workflow in which you have tried the same and please record a short video on how you are connecting the Plutio action step?
Hey @i5marketingincCan you please share the name of the workflow in which you have tried the same and please record a short video on how you are connecting the Plutio action step?
Hi there,
Here is the workflow
Long Pest Email>>Google Task>>Plutio Task
Video of the error
https://i5marketinginc.vmaker.com/record/YsplYy0Q8j7BT1ah
Thanks,
Can you try reconnecting the Plutio action step once, you can also refer to the following video tutorial on how you can connect.
