Problem connecting ThriveCart and Systeme.io
Status: Closed · Asked by François on · 0 views
François — Question ·
ThriveCart and Systeme.io are well supported by Pabbly Connect.
So when I have a customer who buys a training from me via ThriveCart, I would like to create the customer in my Systeme.io contact list with the addition of the right TAGs as well, and have them automatically receive (in my Systeme.io member area) the e-learning training they just bought.
But I can't configure it with Pabbly Connect (although it works fine with Zapier).
Because when I want to create a new workflow, I manage to configure ThriveCart and the elements to take, but then when I want to "Add Action Step" I can't find the Systeme.io App available!
Please tell me how I can automate my sales using ThriveCart and Systeme.io.
Hey @François
Currently, the integration you're looking forward to with Systeme.io is not possible, as we don't have action events available for the Systeme.io application.
You can check all available integrations here - https://www.pabbly.com/connect/integrations/
François — Reply ·
Do you think it will be possible later, by contacting them, as they have an API (and manage webhook) and Zapier uses it fully to offer email creation, member creation for training in member sites, TAGs, ...?
Pabbly — Reply ·
Can you please share the link to System.io public API documentation? As we checked and contacted their team earlier, they haven't provided us with the API documentation so that we can build the action events.
Rico.2refocs — Reply ·
Is there any update already on the action event of Systeme.io?
I need to create/ update a contact and ad a tag.
Thanks!
