Problem connecting Wordpress WooCommerce to Pabbly
Status: Closed · Asked by vuurrood veiligheid on · 0 views
I have been trying to connect my WooCommerce store via the WooCommerce tag and the Webhook tag, but it doesn't seem to be able to capture the response.
Right now we are using the free version just to make sure that this is what we really want and it would be a big step if we where able to connect our store with Pabbly.
Any tips would be welcome.
Please follow the step for capturing the webhook data of WooCommerce as shown in the first part of video here -
Thank you, that actually helped, it seems we made the mistake to not make it active. Is there a way to do both a update and a add new (for mailchimp)? Or do we have to use 2 different ones for that
You can update and add a new subscribers in MailChimp account easily using the Routers option -
You need to first search whether the email is already present in the MailChimp account, then based on whether it is present or not, you can add conditions to add or update subscribers.
Thank you, this will help a lot
