Problem in Workflow. Please Review and Fix...lot of time wasted.
Status: Closed · Asked by vikasgupta2841 on · 0 views
vikasgupta2841 — Question ·
REQUIREMENT
-We have a Google Sheet with 1000 MCQs (multiple choice questions).
-We want to send 3 New Telegram Quiz Poll from this google sheet at regular intervals (defined below) i.e.
  • Send 3 new (i.e next 3 rows of MCQ google sheet) telegram poll
    • a) after every 10 minutes,
    • b) between 7am to 9 am IST
    • c) from 1st to 10th of every month
MCQ Google sheet details:
link:
https://docs.google.com/spreadsheets/d/17WnHyjTnMvjHEhdU_QLs8eTKuXnC3EDQhwc1SZffF9U/edit?usp=sharing
Webhook: https://connect.pabbly.com/workflow/sendwebhookdata/IjU3NmQwNTZlMDYzMDA0M2M1MjZlNTUzMyI_3D_pc
Trigger column: H
Telegram Group details:
  • GroupID: @bpscbsscstudents
  • username for your bot: GoogleSheetsTelegramBot_bot
  • Use this token to access the HTTP API: 6011650870:AAFNBO3dTcxmeLeBT5an3x_gGQjAMHVl2J8
We are unable to connect Google sheets with Telegram such that it sends the next 3 rows as polls to telegram every time between 7 AM to 9AM IST?
PLEASE EDIT THE ABOVE WORKFLOW FOR THIS. ?
Hey @vikasgupta2841,
As per your use case, we have created and shared three workflows with you. Please create a separate folder and keep all three workflows in it.
Workflow 1: Use this workflow to automate the process of sending Telegram Polls from Google Sheets at regular intervals of 10 minutes between 7 AM and 9 AM. To get a better understanding of your workflow, please refer to this thread -
https://connect.pabbly.com/workflow/share/XBRWZFMEVTZWHAZrUwQAJw4aUlYCWAY6Bh9WRAcIUSlRHAdCUxIMZloWBSdTFAZnXhcGbANfATtfSwQAUgRRIlFIVEFTTFUIVmVRFFYJDCZcPg##
Workflow 2: Use this workflow to start Workflow 1 on the 1st day of each month.
https://connect.pabbly.com/workflow/share/D0cFNwRTUzBTGQJvVgEAJw8bV1NQClZqUElURgAPUytWGwRBAUBaMFoWUnBSFQNiAksDaQZZAWUBFQsPVAIIe1JLAyxUSwFcBjVTFgZZWnAPbQ##
Workflow 3: Use this workflow to pause Workflow 1 on the 10th day of each month.
https://connect.pabbly.com/workflow/share/C0MAMlEGBGcHTQBtBVJRdlhMBwMHXQg0VUwEFldYBn5XGgRBUxIIYglFBCZQFwVkUxoEbgFeUzYAFAcDBVMFdlxFCCcDHFUIU2AGQ1cIX3ULaQ##
vikasgupta2841 — Reply ·
Awaiting your response...Please reply
I thought you would be replying as you were viewing my thread
We apologize for the delay. During the testing of your workflow, it was discovered that the Answer Explanation in your Telegram Poll contained double quotes ("). As a result, an error occurred. However, we were able to resolve the issue by replacing the double quotes with single quotes, and the workflow resumed normally. To avoid encountering this error in the future, kindly replace all double quotes in your polls with single quotes.
Whats happening?
The workflow executed successfully but it is sending the SAME ROW (i.e. same telegram poll) AGAIN & AGAIN.
What should happen?
i. It should send the next row as telegram poll every time
ii. After all rows in the google sheet is over it should start again from 1st row
Please fix this.
You need to map the Range as it is given in the screenshot from the previous step.
In the 'Counter, Reset Counter After Reaching Certain Final Value' field, add the number of the last row of your Google Sheets spreadsheet.
