problem salad
Status: Closed · Asked by OlivierFrench on · 0 views
OlivierFrench — Question ·
Task History ID: jU3NjUwNTY0MDYzMjA0M2M1MjZmNTUzMTUxM2Ii_pc
Hello
I CAN'T GET THE RESULTS WITH SALAD... I HAVE AN ERROR MESSAGE SEE IMAGE... DO YOU HAVE A SOLUTION
Hi @OlivierFrench,
The Workflow ID you shared doesn’t appear to be correct. Could you please share the Workflow ID or URL again?
OlivierFrench — Reply ·
Hi @OlivierFrench,
yes I deleted it to start a new one
I'm looking for a solution to transcribe a youtube or tiktok video... I want to connect them with salad but I get an error message every time...; have you found a solution to get a transcription that works.
Fagun Shah — Reply ·
Salad doesn't support YouTube or Tiktok URLs, you need to pass direct video URLs, ending with .mp4 or direct audio url ending with .mp3
Fagun Shah
- Automation Freelancer
ok comment faire pour changer ou avez vous une astuce ?
It's not possible to convert a YouTube URL to a direct publicly accessible video or audio URL. The use case you are describing does not appear to be feasible.
You have to use RPA tools like Zerowork or Robomotion in between to get the MP3 URL and then use that for Salad step.
Fagun Shah
