Problem Webhook Clone Workflow
Status: Closed · Asked by amicici on · 0 views
When I clone the workflow where the first operation is a weebhook inside it happens to me:
1. It does not vary or does not make us choose whether it is of interest to us to change the landing link.
2. Cloning it and using the same link, it does not receive any data within the clone Workflow.
3. It is impossible for me to experiment.
The intention of carrying out a workflow cloning and not wanting to repeat everything from scratch and to make adjustments without compromising the previous one that maybe I deliberately leave running.
Therefore please fix this bug by making us users choose whether to replace the landing link and more importantly if it clones it and leaves the same link, this must work, otherwise we are forced to reprogram everything from scratch.
It is impossible to work like this, as a first thought, you must understand that those who use your services, the time factor is IMPORTANT, your platform is beautiful, but it must be considerably streamlined and more importantly we can allow us to move, clone and make group changes in addition to transferring many elements with simplicity. (see zapier) !.
The two workflows I refer to within my account are:
CLONE - reschedule and cancel
Hey @amicici
Whenever you are cloning any workflow which has a webhook in it, then please note that it will create two different links.
Thanks for sharing the feedback. We will pass it on to the technical team. Pabbly connect is in the stage of an evolving process. Our technical team is working on many new integrations on daily basis.
Kunal
Yes you are right, sorry the data was not being transmitted because there was a compilation error in my program.
