Problem with clickup automation
Status: Closed · Asked by Antonio995 on · 0 views
Antonio995 — Question ·
Hi!
I set up my automation with clickup to clickup. The automation is "when a task is created in a certain list, create a list in another folder". So, If i set up the first time this automation works, I create a task, and after 8 seconds a list is created in the folder.
But if I activate two similar automations, "when a task is created in the list#1, create a list in another folder" and "when a task is created in the list#2, create a list in another folder" the second one doesn't work.
Like you can see in the attachment, when a task is created in "vendite", in the folder "Fase Operativa BR" is created a list with the same name of the task created. When a task is created in the list "permute", no lists are created in the folder "Fase Operativa BR"
Can you help me?
Antonio995 — Reply ·
Testing it I found that the list is created, but not instantly... sometimes happens after 10 minutes... but only if I create a task in lists "permute" or "lead gen". If I create a task in list "vendite" immediately creates a list in the folder "Fase operativa BR". Any solution? I need that this connection happens instantly
Hey @jondo95
Could you please share your registered email address with Pabbly and the respective workflow in which you are having this concern so that we can look into it and can assist you accordingly?
