Problem with Extract Phone Number Step
Status: Closed · Asked by mikec29526 on · 0 views
My step 16, extract phone number from Google Calendar Description Field - can you look at it and see why it failed for this particular task?
Task ID -
IjU3NjYwNTY0MDYzMDA0M2M1MjY1NTUzYzUxMzM1MTYzNTQzOCI_3D_pc
executed at
Oct 15, 2022 09:00:22
Hey @mikec29526
If you can see the trigger response of Google calendar in your workflow, it seems like the field which you are using to extract the phone number is missing and because of that, your Extract Phone number action didn't get any data whereas it gets failed.
Please make sure that the label which you are using has the required data.
