Problem with Google Calendars
Status: Open · Asked by virsingh77 on · 0 views
virsingh77 — Question ·
Am facing an issue creating a detailed event in google calendars in both my workflows, namely:
Ecwid to sheets
Sheets to calendar
I have made no changes to both the worflows but have started getting errors in the part where a detailed event is to be created using google calendars.
The error being given is at the location reminders.overrides.minutes and the error message is Invalid value for Integer: numeric(0
I have tried to set the value of the field Minutes Before Reminders to 0 but that also doesn't help
Some sample task ids are:
IjU3NjUwNTZlMDYzMTA0M2Q1MjZlNTUzMDUxM2E1MTY1NTQzNjBmMzci_pc
IjU3NjUwNTZlMDYzMTA0M2M1MjZiNTUzNTUxMzU1MTYxNTQzNzBmMzki_pc
Can someone pls help!!
Hello @virsingh77,
Thank you for bringing this to our attention.
Please try clicking on the "Refresh Fields" button in the Google Calendar (Create Detailed Event) action and re-map all the required fields again. This often helps resolve such issues caused by recent changes in the app or field structure.
If the problem still persists after doing this, kindly share the workflow URL so we can investigate the issue further.
