Problem with GOOGLE FORM (trigger) and Active Campaign
Status: Closed · Asked by The_One_Piece_Is_Real on · 0 views
I need some help.
I have created a workflow that connects google form to active campaign.
The answers from the questionnaire need to be saved to the contact details of active campaign.
When I click "Save and send test request" everything works fine. But then when I fill out the questionnaire outside the test, it doesn't work.
What could be the problem?
Hey @The_One_Piece_Is_Real
You need to use the "Send On Event" option when setting up Google Sheets if the data is coming from a Google application or if you manually enter it.
If the data is coming from a third-party application, however, you may need to choose "Auto Send On Schedule" which will forward the data in exactly one hour.
Please refer to the following video for a better understanding:
(watch 1st part of the video)
Hey @The_One_Piece_Is_RealYou need to use the "Send On Event" option when setting up Google Sheets if the data is coming from a Google application or if you manually enter it.
If the data is coming from a third-party application, however, you may need to choose "Auto Send On Schedule" which will forward the data in exactly one hour.Please refer to the following video for a better understanding:
Thank you very much Arshita ,
Problem solved.
