Problem with Google Sheets
Status: Closed · Asked by medusa on · 0 views
I am a new Pabbly user and currently learning how to use this tool. I created a new workflow with Google Sheets as trigger. Configured Google Sheets like in the documentation (Trigger when col A changes) and did a test send & then submit.
The data is showing in Pabbly but only the trigger is submitted not the row. I tried it several times and I do not get the new row but only the trigger.
How can I get the row instead?
Thank you all ;-)
Hi @medusa,
Please ensure that the Trigger Column in your spreadsheet is the last column of your row which contains data. Otherwise, any data entered in columns before it will not be captured.
For example, if I set column B as the trigger column, only the data entered in columns A and B will be sent to Pabbly Connect.
Dear ArshilAhmad,
thank you, that solved the problem :)
Kind regards,
