Problem with Nativeforms -> Sendinblue transactional
Status: Closed · Asked by tcup on · 0 views
tcup — Question ·
Hi. I have just found that my workflow breaks when the message in Nativeforms contains " " punctuation. Sendinblue gives the error - Input must be a valid JSON object.
How do I fix this, please?
PabblyMember4 — Reply ·
Hey @tcup
You are passing double quotes in the HTML body inside Sendinblue- Send a transactional email because of which you are getting that error message. We have included text formatter - Replace text and replace the double quotes"" with single quotes and then passed the mapping into Sendinblue and run it successfully.
Kunal
tcup — Reply ·
Thanks so much for your fix.
You're welcome :)
