Problem with pabbly responses in json!?
Status: Closed · Asked by Andres Diaz on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY1MDYzNTA0Mzc1MjY5NTUzMTUxMzQi_pc
Task History ID: https://connect.pabbly.com/task/history?filter_status=applied&filter_by_workflow_id=IjU3NjYwNTY1MDYzNTA0Mzc1MjY5NTUzMTUxMzQi_pc
Hi, i have this problem, in the responses that pabbly gave me in google sheets, quickbooks etc, every response is in json, like an array, and it was not this way, so i need help to fix it. ScreenShots Below.
Hello @Andres Diaz,
Thanks for sharing the screenshots.
It seems the issue might be due to browser cache. Kindly try the following steps:
- Clear your browser cache and refresh the page.
- Open the specific action step and select Response Format = Simple.
- Click Save & Send Test Request again.
Please let us know if the issue still persists.
